Discuss productivity tips for 2nd fix wanted in the UK Electrical Forum area at ElectriciansForums.net
i like them. you can get within 3/4" of the cable entry into the back box, leaving a nice clean cut of the sheath, so it don't look like you've chewed it off.These for stripping twin and earth cable.
Jokari FKZ Automatic Flat Wire Stripper
Tools, power tools, hand tools, electrical, plumbing supplies, ffx tools, FFX, The Jokari FKZ Flat Wire Automatic Stripper is an ergonomic, automatic wire stripper which is suitable for PVC-insulated flat cableswww.ffx.co.uk
Probably be no use as everything wired in LSFThese for stripping twin and earth cable.
Hi surly that method would use up more energy going to each point twice. I use a little step helps. Lot.cut corners like every other house basher. No sleeving, half tightened screws... grab the money and run.
only kidding
Time can be wasted by digging out plaster from boxes and sorting out cables that the plumbers had cut identifying markings off "for a laugh"
When I was younger, and a little more agile, I would go round a room one tool at a time.
ie, knife at each point for stripping back the sheath, then pliers to cut each conductor, then wire strippers, then screwdriver.
Added a little variety to a mundane job.
Now I need a little cushion to kneel on.
So that wire stripping tool actions strips lsf ? As I own a automatic wire stripping tools but does not strip lsf. I may have to buy that Jokari if it works wellYou can similar for lsf. Did farmhouse conversion with lsf, and the stripping tool was invaluable. Only prob was there was only two on site.
Reply to productivity tips for 2nd fix wanted in the UK Electrical Forum area at ElectriciansForums.net
