How to increase cable length? | on ElectriciansForums
Discuss How to increase cable length? in the UK Electrical Forum area at ElectriciansForums.net
London
Hi guys,
Im very new to this forum so thanks for hearing me out.
I have an led light that is waterproof. The issue im having is that the cable is not long enough for its purpose. I needed some help or advice as to how i could find a cable attachment to increase its length.. i have attached pics to see the connectors.
Any help appreciated.
Thanks guys!
[ElectriciansForums.net] How to increase cable length? [ElectriciansForums.net] How to increase cable length? [ElectriciansForums.net] How to increase cable length? [ElectriciansForums.net] How to increase cable length?
Hi guys,
Thanks guys!
Welcome to the forum mate.
As above, soldering & good quality heat shrink is fine to extend the cable.
What length is the existing cable?
What length do you require?
Asking because of voltage drop as the LEDs are 12V
Hi mate. Thanks for that!
The light itself is 30W and the cable is 7.5m
i need at least another 5m cable to be attached.
I was wondering if i could buy a cable which has a male to female attachment? that i could just attach to it? any thoughts? and what they are called?
I bet the manufacturer makes an extension cable. have a look at there web site.
Hey bud, thanks for that. I was typing some different terms in ebay and amazon and i think ive finally found it :) its 2pin gaden light extension cables. Thanks for all the help everyone! Just ordered a 5m cable and will let u guys know if it works :)
hey guys, so the one i ordered didnt work :( the socket was way too small. I have now found out that the plug is an IP68. Guys, any idea how i could go about making the cable longer?
Sorry to hear what you got didn't fit.
So post some more pics up of what you have now and what you bought.
Could you not rewire what you have now using something like the connectors @buzzlightyear posted above?
Reply to How to increase cable length? in the UK Electrical Forum area at ElectriciansForums.net
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
Quality varies wildly. OE cables supplied with expensive items tend to be considerably better than unbranded replacements available on the high...
nicebutdim
N
