Discuss 2 gang light switch to a smart light switch in the Lighting Forum area at ElectriciansForums.net
Think you will find that your smart switch will require a Neutral to ensure it will work.Hi looking for some advice if poss. Recently I purchased a smart switch to replace on in my man cave and I'm a little stuck on how to wire it up. It controls 2 lights no 2 way switching. I have attached 2 pics one of my existing switch and one of my smart switch all input is appreciated thanks.View attachment 52698View attachment 52699
Was thinking the same, if both on same circuit swap 1 perm live over to a switch wire and use the blue as a neutral and all should be fine.I was actually thinking along those lines. If both switches are on the same circuit you could repurpose one wire as a neutral.
I have 3 blue neutral cables connected in old switchIgnore me......beer!
I know mate I wasn’t looking with me glasses on ? sorry!I have 3 blue neutral cables connected in old switch
Reply to 2 gang light switch to a smart light switch in the Lighting Forum area at ElectriciansForums.net
