2 gang light switch to a smart light switch | Page 2 | on ElectriciansForums
Discuss 2 gang light switch to a smart light switch in the Lighting Forum area at ElectriciansForums.net
I was actually thinking along those lines. If both switches are on the same circuit you could repurpose one wire as a neutral.
Was thinking the same, if both on same circuit swap 1 perm live over to a switch wire and use the blue as a neutral and all should be fine.
Hi just wanted to thanks everyone who posted replays to my question I fired my switch last night doing exactly as instructed marking the cable with blue shrink wrap and swapping it to the neutral and it works great. Thanks again.
Hi all
I have problem change my old 2gang 2 way switch to smart switch . If someone can help, will be great for me :D
Please see pictures
White L1 and 2 brown in com are live when light is off
  • [ElectriciansForums.net] 2 gang light switch to a smart light switch
Reply to 2 gang light switch to a smart light switch in the Lighting Forum area at ElectriciansForums.net
brilliant thanks for your support. Lee
Yes the neutrals will be connected together in the same terminal and the earth joined in a 2screw earth connector just behind the switch.
