step by step is best. break each section down, understand the workings, then combine all together.
Discuss Direct online forwarding and reverse. in the Commercial Electrical Advice area at ElectriciansForums.net
Ok , Easy wiring diagram but , I doing step by step .
Using the same method , 3 phase wiring brown, black and grey.
Can you asking for writing wires diaThe Forward Contactor will be the one with the Forward Start pushbutton wired to the N/O of that contact.
or if nothing is labelled up then:
As the Forward & Reverse circuits are functionally the same then just pick one for Forward and the other for Reverse. The actual Forward & Reverse wiring for the motor is not part of this circuit.
[/QUOTE
Finally done last night.
Finally done last night. Thank you for Help .Ok, so just so that I'm clear on this: You are just following the drawing and picture, to see how it works and not actually wiring anything up?
Iitle unfers you need help in DOL forward and Reverse of a motorGood morning again ,any Idea I looking for example cable sizing.View attachment 53253View attachment 53254
[automerge]1571565704[/automerge]
I know , but I don’t like make new post .Iitle unfers you need help in DOL forward and Reverse of a motor
I little be confused theory now , I not have proper book,Any idea where did I find examples test .
I’m ready too pay small amount ££££.
Pdf file .
Thank you .
Ok I got book I try to work out and show you my home work .Hi mate.
It's best if you do new questions in a new post mate.
Also, if you are going to get into electrical design then you need to get the BS7161 book.
IET Wiring Regulations 18th Edition
#html-body [data-pb-style=THAG3L6]{justify-content:flex-start;display:flex;flex-direction:column;background-position:left top;background-size:cover;background-repeat:no-repeat;background-attachment:scroll;border-style:none;border-width:1px;border-radius:0;margin:0 0 10px;padding:10px}#html-body...www.test-meter.co.uk
Also, with questions like the above, we don't like giving out answers without you first attempting to do the question and showing us your workings-out. Then we can correct anything. It's the best way of learning.
Thank you .Yes, I'd observed that. There should really be a N/C contact from each direction's contactor inhibiting the other direction's coil circuit. Wouldn't stop the operator hitting stop then reverse immediately - but it would stop them just hitting reverse.
Mind you, the mechanical interlock would deal with that - but IMO it would be poor design to be relying on that rather than designing the control circuit correctly.
Never be late .?Ah yes, so there is. Too late in the evening for my memory
All done forward and reversed for now .I think @Zaprinski wants to know about the question in his post #31 now, but didn't start a new thread so things are getting mixed up. I think he has sorted the starter question as he says he built it in his post #29.
For his question in post #31 he is getting the BS 7671 book and hopefully will attempt the question himself. We can then look at his results and correct anything. Always better to try yourself and then ask where you went wrong.
Reply to Direct online forwarding and reverse. in the Commercial Electrical Advice area at ElectriciansForums.net
