Iitle unfers you need help in DOL forward and Reverse of a motorGood morning again ,any Idea I looking for example cable sizing.View attachment 53253View attachment 53254
[automerge]1571565704[/automerge]
I know , but I don’t like make new post .Iitle unfers you need help in DOL forward and Reverse of a motor
I little be confused theory now , I not have proper book,Any idea where did I find examples test .
I’m ready too pay small amount ££££.
Pdf file .
Thank you .
Ok I got book I try to work out and show you my home work .Hi mate.
It's best if you do new questions in a new post mate.
Also, if you are going to get into electrical design then you need to get the BS7161 book.
IET Wiring Regulations 18th Edition
#html-body [data-pb-style=THAG3L6]{justify-content:flex-start;display:flex;flex-direction:column;background-position:left top;background-size:cover;background-repeat:no-repeat;background-attachment:scroll;border-style:none;border-width:1px;border-radius:0;margin:0 0 10px;padding:10px}#html-body...www.test-meter.co.uk
Also, with questions like the above, we don't like giving out answers without you first attempting to do the question and showing us your workings-out. Then we can correct anything. It's the best way of learning.
Thank you .Yes, I'd observed that. There should really be a N/C contact from each direction's contactor inhibiting the other direction's coil circuit. Wouldn't stop the operator hitting stop then reverse immediately - but it would stop them just hitting reverse.
Mind you, the mechanical interlock would deal with that - but IMO it would be poor design to be relying on that rather than designing the control circuit correctly.
Never be late .?Ah yes, so there is. Too late in the evening for my memory![]()
All done forward and reversed for now .I think @Zaprinski wants to know about the question in his post #31 now, but didn't start a new thread so things are getting mixed up. I think he has sorted the starter question as he says he built it in his post #29.
For his question in post #31 he is getting the BS 7671 book and hopefully will attempt the question himself. We can then look at his results and correct anything. Always better to try yourself and then ask where you went wrong.
Reply to the thread, titled "Direct online forwarding and reverse." which is posted in Commercial Electrical Advice on Electricians Forums.
