So a bit of fun as it is a bit quiet. This is mine been there since I moved in and has all the required notices and selected additional protection. The first Proteus one wins the wooden spoon.
Discuss Show us your consumer unit. in the UK Electrical Forum area at ElectriciansForums.net
because they get plumbers to install them. .Out of all the CU’s on show, why is it the non-electricians that looks the tidiest?
my solution (at home, i hasten to add), was to supply all garage circuits ( with 4 freezers on, and my bench and 'er indoors sauna) from a 40A MCB, no RCD. the 2 outside socket outlets are RCD sockets, just in case she cuts the mower cable again.When I did last house around 1990 getting RCD's in side the consumer unit or fuse box not sure when the type tested type came out, was hard, and the RCBO was only around as a two unit width two pole device.
So two RCD's and two fuses boxes with MCB's replacing the fuses. Today there is no excuse for using RCD's the RCBO's have dropped in price and having just lost a freezer full of food when a RCD tripped simply not economical to fit RCD's feeding many MCB's any more.
But at what point does one upgrade? When you have a serviceable distribution unit at what point does one say this needs changing? And what do you do with the stuff removed which is OK, and as it was when new?
Rewired house and changed the cu afterwards.
View attachment 53136 View attachment 53137 View attachment 53141
can't do open box just yet. will do within a day or so. closed box be on here later.Let's see yours Tel.
Reply to Show us your consumer unit. in the UK Electrical Forum area at ElectriciansForums.net
