Connection above or below terminal screw plate | on ElectriciansForums
Discuss Connection above or below terminal screw plate in the UK Electrical Forum area at ElectriciansForums.net
Kitkat
Ann Arbor
Does a wire attaching to a screw terminal on a standard receptacle outlet go over or under the little brass movable plate, please? Thanks
  • [ElectriciansForums.net] Connection above or below terminal screw plate
Reply to Connection above or below terminal screw plate in the UK Electrical Forum area at ElectriciansForums.net
