hferozan91
Please see my photo for description.
Discuss Need help with rewiring in the UK Electrical Forum area at ElectriciansForums.net
I guess, although you would need a fcu and then switches downstream obviouslyIt is acceptable in the US to have receptacles on the same circuit as the lighting in fact there is nothing stopping this in the UK.
@hferozan91 you may be able to reconnect the switch so the receptacle is permanently on it depends if it is separate from the lighting at the switch.
Lights and sockets on same circuit was the norm in most European countries in the past, although the UK model is definately becoming the "new norm"It is acceptable in the US to have receptacles on the same circuit as the lighting in fact there is nothing stopping this in the UK.
Reply to Need help with rewiring in the UK Electrical Forum area at ElectriciansForums.net
