Discuss what type of 10AX 1 way switch is this- can I get replacement in the Lighting Forum area at ElectriciansForums.net
can you suggest larger electrical supplier than stock similar? All switches are like this.the switch itself is broken. my local electrical outlet said they could not order.View attachment 85307
thanks this looks near enough so I'll order it and then book someone to install it. appreciate your help ?You will probably have to get one online.
Screwless 1 Gang 2 Way 16AX Rocker Switch in White Metal Flat
Sparks Electrical Wholesalers sells a wide range of electrical items including Screwless 1 Gang 2 Way 16AX Rocker Switch in White Metal Flat Plate White Trim.www.sparksdirect.co.uk
thanks for recommendations and your help on this?Don't know about in Ireland.
But
City electrical (cef)
TLC
Edwardes
Even ebay usually has them
EDIT
And Amazon, free delivery by Monday
CEF do list them. Don't worry it states 16A it makes no difference.
16A 1 Gang 2 Way Screwless Switch White Insert Painted White
1.5mm plate thickness provides a design-led alternative to traditional accessorieswww.cef.co.uk
Reply to what type of 10AX 1 way switch is this- can I get replacement in the Lighting Forum area at ElectriciansForums.net
