Why does a fridge freezer fail an insulation Pat test? | on ElectriciansForums
Discuss Why does a fridge freezer fail an insulation Pat test? in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Manchester
Hi, I am getting a reading of 0.00MOhm
I've never had this before, it's not tripping the rcd.
I was wondering if it may be damp but can't see anything obvious.
Any ideas please?
It's not very old.
Had one once where the heat from the interior lamp was melting ice (that had formed where it shouldn't have) when the door was opened, the liquid ran down onto live parts near earthed metal and tripped the RCD a minute or so later. Water then froze again, so IR was good again when tested.
Reply to Why does a fridge freezer fail an insulation Pat test? in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
