I have a replacement LED driver for a lighting circuit that had normal halogen G4 bulbs. The forum has already put me onto the right track by explaining that the LED do not draw enough current to allow the original transformer to operate, so thank you for that.
However, my problem is I have removed the board from the casing and now cannot work out which side is the AC inlet and which side is the DC output. (Sarky comments accepted as what a pillock).
Any guidance would be very much appreciated please?
Woodersd
Woodersd
