Switching device ? | on ElectriciansForums
Discuss Switching device ? in the UK Electrical Forum area at ElectriciansForums.net
Wiltshire
working on a kitchen refurb, customer wants to relocate washer and drier.
There is only one socket close by on the ring. Rather than spur from another point which will be tricky, anyone know of a device that switches between appliances so only one can be used at once ?
Can't you just spur another socket side by side or turn what I assume is a single socket into a double??
like this:
  • [ElectriciansForums.net] Switching device ?
Reply to Switching device ? in the UK Electrical Forum area at ElectriciansForums.net
Probably a bit late for the OP, but there's a very easy option if a manual solution is OK. Rotary cam switches are just the ticket - but not the...
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
Ah OK, that makes sense. Thank you Avo.
Red fp200 gold and white FP200 from Pyrsiiam are both UV rated. That said they both eventually show signs of being outside and I used to avoid...
