Ring hardwired doorbell jumper cable | on ElectriciansForums
Discuss Ring hardwired doorbell jumper cable in the UK Electrical Forum area at ElectriciansForums.net
Richard Cook
Sheffield
I’m looking to finally connect my Ring Hardwired doorbell. The existing bell has 4 wires going to it; two from doorbell and two from transformer at consumer unit.
I’m wondering if you have any advice where the jumper cable needs to go? And to be honest I’m wanting to get rid of the bell so can just connect the wires as obviously the doorbell needs full power so needs to bypass the bell so can just reconnect them.
Has anyone got any suggestions?
  • [ElectriciansForums.net] Ring hardwired doorbell jumper cable
Reply to Ring hardwired doorbell jumper cable in the UK Electrical Forum area at ElectriciansForums.net
That seems a very good shout. I’ll test that
Hi, How did you install your doorbell in the end?
Second Update: 12/25/2023 Hey everyone, so I solved my doorbell issue. Turns out there were two reasons why my doorbell wasn't turning on. 1.)...
Ok great, I’ll give that a go. Thank you
Yes that will do the job - presuming there is a battery in it and it's working Ok! Turn the rotary knob one click to the V setting as you say...
