oohaardvark
Hi, non-electrian here. Just bought a 50's house with old electrics. I expect everything will need replacing eventually, but I can't afford to have it all done at once.
I imagine it's best to start at the supply and work out from there, so I think the priority is a new consumer unit - it's got Bakelite wire fuse holders still!
Trying to engage an electrician to do this job, he says he must do an EICR first, otherwise if he puts a new CU on bad wiring it could 'blow up the whole board'.
Now I'm no sparky but that makes no sense to me. Why would you do all the tests on a system you know is non-compliant? It'd be like taking a car for MOT with flat tyres.
Re. a bad circuit killing the CU - firstly all the circuits currently work, so I can't see how it could be that bad. Secondly, the whole point of RCD+MCB or RCBO is to make the system survive and isolate such faults surely?
Also, I thought EICR was for landlords and tenants, not private owners?
Very much ready to be corrected, I know nothing.
- TL;DR
- as a homeowner with a known bad CU, why would I have an EICR done before replacing CU?
