Light Flickering and LED won't fit in holes | on ElectriciansForums
Discuss Light Flickering and LED won't fit in holes in the Lighting Forum area at ElectriciansForums.net
UK
Hi all.
I have a few issues:
- I bought an LED spotlight which is 50w (Input power 7.8w) 240v, but it flickers when I turn the lights on. There are 2 other older bulbs in the circuit which are 12v 20w..... When I take these other two out and just leave the new 50w LED bulb in it still flickers. There is no dimmer switch for these 3 lights. Also, when I look online for 12v 20w bulbs the only bulbs that come up are halogen. So what bulb do I need to buy to stop the flickering, I want LED, not halogen.
- Second issue is that in another area of my home, the LED bulb prongs that I bought don't fit in to the holes on the fitting. The bulb prongs are just ever so slightly too far apart to fit in the holes no matter what way I try to put it in. Also, what holes should it actually fit in to (see image)? I have tried all holes.
Cheers guys.
  • [ElectriciansForums.net] Light Flickering and LED won't fit in holes
First, you can’t run a 240v bulb with only a 12v supply. You need a 12v bulb.
just have to keep looking. There are LED bulbs now for every type of normal incandescent or halogen. Don’t search for the W value, just the voltage and the cap type. (The shape of the pins that the bulb plugs into)
in the second question, I don’t think that is a specific lamp holder. Just seems to be a connector socket.
The existing lamps are 12v and you'll have a transformer in circuit.
You'll need to change the transformer for a LED driver as it is not compatible and can cause flickering.
The lampholder needs changing to a GU5.3 lampholder as not sure what you currently have?
If I'm reading it correctly, you have 3No. 7.8watt LED lamps (I doubt they are 50w) so will need a 25w (or higher rated) led driver.
Hi all.
Cheers guys.
Don’t get me started on lights flickering ?‍♂️?
Ah ok I was searching for the W. Now I have searched for 12v LED and I can see some options. They seem quite pricey though.
Regarding the connector socket. What do I need to buy for this so I can fit a LED bulb?
you need to take the transformers out, feed the 240V directly into a GU10 lampholder, observing safety and regulations concerning connections. then fif GU 10 lamps/bulbs.
Reply to Light Flickering and LED won't fit in holes in the Lighting Forum area at ElectriciansForums.net
For my hapeneth and learnt from hard recent experience, the term LED transformer and driver tend to be used interchangeably, when they are...
Neutral and live
