How to use Memera 2000 program planner | on ElectriciansForums
Guest viewing is limited
Discuss How to use Memera 2000 program planner in the UK Electrical Forum area at ElectriciansForums.net
tonysc
Newbury
Hi Everyone,
Hope you are well.
I've just moved into a flat. It has got economy 7(duel electricity tariff) floor heating/boiler. The mains switch is Memera 2000 and it has got a program planner as attached. Do you guys know how to configure the program planner so it switches on only at off-peak hours?
Much Appreciated & Kind Regards
Tony
[ElectriciansForums.net] How to use Memera 2000 program planner
  • [ElectriciansForums.net] How to use Memera 2000 program planner
Nobody?
It seems the timer made for that CU is a MEM AT1P or AT2P
Unfortunately so far I haven't found any instructions for it on the web ☹️
The same question was asked here in 2014 with a rather unhelpful response/outcome:
It's listed in the Memera old catalogue on the web, but the AT2P looks different to yours, so perhaps it's an AT1P.
I guess as a last resort it's a question of pushing buttons and seeing if you can work it out 🤔
I recognise the pic as being very similar to one I had in use a few years back, that I'd also installed to control storage heaters in a property on a sub main. Storage heaters and timeswitch are now long gone.
From what I remember, it wasn't the easiest thing to program, but did respond to button pushing and a bit of logic.
Is this a rented property? If so, I see another problem if a conscientious EICR is ever carried out.
There's a big hole into the inside of that consumer unit
Reply to How to use Memera 2000 program planner in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
Recommended Sponsor News
Hi everyone,
