A quick European wiring puzzle with a simple answer | on ElectriciansForums
Discuss A quick European wiring puzzle with a simple answer in the UK Electrical Forum area at ElectriciansForums.net
Lucien Nunes
Mentor
London for the time being
Following from a recent thread mentioning some continental electrical practice, I made this mock-up of something you might see in an older installation in a certain West-European country. It's not standard practice now but is widespread enough to have a specific name. What is the name of this specific circuit arrangement in the local language? Not sure if we have any sparks from the country in question on here but please let the Brits have a try!
[ElectriciansForums.net] A quick European wiring puzzle with a simple answer
@Vortigern you win. Klassische Nullung. And very popular indeed in Finland until quite recently (was it 2001?) where a CNE conductor was often of larger CSA , I think they were the last to forbid it. And @Dustydazzler yes in the USA it's called a bootleg ground and is deprecated; their preference for grandfathered 2-wire circuits is to enforce retrospective 5mA GFCI installation and leave the EGC / ground terminal disconnected.
My mockup shows an example of an old installation with no CPC in the original black/grey section dating from the 1950s. In 1969 it became standard to run 3-core cable to new points, with a blue neutral and green/yellow CPC, but it was permissible to connect both to the existing grey neutral.
I first met this in 1987 when I was tasked with putting up a fluorescent batten in premises with a 2-core lighting circuit. The local electrician told me to link the CPC and N terminals in the fitting which seemed like the weirdest thing at the time but I got used to it. Couldn't resist checking as many upstream neutral terminals as I could in the available time, to ensure there wasn't something about to drop off and send the fitting live. The workmanship was good and I couldn't see any likely problems. No RCD of course then.
OK next.
Name and usual application of this (upside down) accessory?
OK next.
It's not one of the larger type of foreign telephone sockets is it?
Connect telephones to that at your own risk. Likely to go up in smoke.
Note I've put the cutters there to hide some markings but I left an important feature visible.
It's two things fitted together, lying with the back of one of them uppermost. There are mounting screwholes in that part.
Seen lots of stuff like this in the three years plus vI spent working and living in the former USSR during the mid 1980s
It's not Schuko but it's derived from that. It's not got 8 pins like the Bulgin but it has got more than 3.
Domestic / light commercial usage. Available in 16A and 25A versions.
@tinhoward you win this round, 16A Perilex, often used as a cooker plug in domestic 3-phase installations that are common in mainland Europe. 3x16A = equivalent to 48A single phase so plenty of juice for any kind of cooker. Increasingly though, where you have a single-phase oven, and a hob that can use 2 phases out of 3, Perilex gets used on single-phase installations with two line pins and two neutral pins. A bit naughty, I've seen it done with either L1 or L3 as the second neutral, usually marked on the front in sharpie.
The 25A version is not as widely used, the two are distinguished by the orientation of the flat, central earth pin, horizontal = 16A, vertical = 25A.
I like them too although the contacts on some of the basic sockets are not as well engineered as many Schuko sockets of the same rating.
  • [ElectriciansForums.net] A quick European wiring puzzle with a simple answer
Reply to A quick European wiring puzzle with a simple answer in the UK Electrical Forum area at ElectriciansForums.net
Reaching out for some help/guidance and sanity check. Apologies in advance for the long post, but wanted to make sure it was clear. Thanks in...
Youre in the same boat as me. I was previously with niceic and later on, napit. No issues. I didn't bother finishing my nvq3 as in 2010 during the...
shambolic also the Logic course needs to be slung.
4K
E
If you want to save on your monthly electric bill and reduce your greenhouse gas emissions at the same time, you might buy a new, energy-efficient...
Electricity News --
E
B
Common chaps you can't argue DPG's point. Brown circular JB's have been around donkeys years. They were designed to be fixed to a surface, joist...
9K
