Tool for 45 and 90 Degree Cuts on PVC Trunking | Page 2 | on ElectriciansForums
Discuss Tool for 45 and 90 Degree Cuts on PVC Trunking in the Electrical Tools and Products area at ElectriciansForums.net
years ago, my dad wanted a mitre block. he made one from some scrap timber, similar to this:
[ElectriciansForums.net] Tool for 45 and 90 Degree Cuts on PVC Trunking
If I had a job that required a lot of trunking to be cut then I might be tempted to buy a cheap chop saw...
But for a one off cut then a cheapo hacksaw and mitre box is fine
That does look okay to be honest. I am looking to buy this one:
When buying a chop saw a main consideration is the adjustability of the fence and if it mitres on both sides of 90 deg, real pain if only on one side.
If it only cuts one way then you will need to wire in circles 🙃
I’ve never had one or even used one. I think it’s a tool that you would use more than you think.
If you have lots of trunking to cut then a chop saw is great , I have one I used when I laid all my laminate at home it was so easy and cuts straight every time
Unless I was cutting pvc trunking all day every day, I can't imagine going to the hassle of hauling a chop saw around.
I remember once reading about someone on this forum using a grinder to cut dado trunking and was appalled at the idea. Turns out it was a great idea and I've used nothing else since.
Think of the fringe benefits , 20 mins to get out and set up the chop saw , 20 mins to measure and cut your 2 lengths of mini trunking , 20 mins to clean up the mess and put the chop saw away...
Thanks a full hours pay you can bill the customer and the easiest 80 quid you will ever make 🙃
Reply to Tool for 45 and 90 Degree Cuts on PVC Trunking in the Electrical Tools and Products area at ElectriciansForums.net
