Just seen these in a TLC advert for "221-2411 Inline Lever Connector":
Looks like a handy thing for some situations.
Discuss in-line Wago connector in the Electrical Tools and Products area at ElectriciansForums.net
I found a kitchen recently that had lots of these:All they need to do now is design a 3 way one and a small maintenance free box for it, then you can use them when people drill through a cable and the cable can't be replaced.
The containment for them was expanding foam filler.In Line Spring Lever Connectors
Use these 32A spring lever connectors for an easy, fast-fit connection. The levers are a real time-saver, and the compact design makes them easier to work with in confined spaces.• 3 in 3 out inline lever connectors• Spring levers for easy, fast-fit connections• Colour-coded for live, neutral...www.toolstation.com
I think that was the Wago connector that was Chinese copied... before Wago even made it ! Looks like Wago have now decided to make em...Just seen these in a TLC advert for "221-2411 Inline Lever Connector":
Yep, still not aware of an official Wago version.I think they are still the unbranded ones. Not Wago.
I've used them - they are fine.
I've never quite understood the 4mm in brackets. Is that if you have iron-bru and push very hard?!
I have seen that with DIN terminals where the larger size is single solid core, and the smaller the stranded size. Odd, as I would have expected it the other way round!I've never quite understood the 4mm in brackets. Is that if you have iron-bru and push very hard?!
Official 100% wago have them in Denmans and Rexel.I think they are still the unbranded ones. Not Wago.
Reply to in-line Wago connector in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
