As far as elecrical power wiring is concerned, it is mainly a language difference as mentioned above
British English: Earthed.
US English: Grounded.
For example, the terminal connected to the metal body of a fixture would be called the 'earth terminal' in British English but the 'ground terminal' in US English. The function is the same.
In electronics the usage of the terms is different. Earthing and grounding are sometimes used interchangeably, but in British English especially they can be used with different meanings:
Earthed: Connected to earth potential.
Grounded: Connected to the signal / power reference (common) potential, which might or might not be earthed.
For example, in British english I would speak of the green/yellow wire of the power cable to an audio mixer as 'earth' but the shield (screen) of an audio cable within it as 'ground.' This has changed over the years. An British electronic technician in the 1930s would likely have called the signal common 'earth' rather than ground.
In British English we sometimes use 'earth' or 'ground' to refer to the chassis of a motor vehicle, and speak of an 'earth connection' when in theory it is technically a neutral, i.e. a return conductor carrying load current that is near earth potential. This is an old-fashioned usage that has continued to the present day.
I’m sure some DC power supplies use “GND” instead of a negative symbol.
However the ground terminal is not always negative, e.g. many analogue electronics use both a positive and a negative supply relative to a common terminal, which might or might not be earthed but is often referred to as ground because it is the power and signal common connection. In this case the negative and the ground are two different things. A single supply with its negative grounded could use the terms 'positive' and 'ground' for the two wires.
There is no theoretical distinction between AC and DC as far as the difference between earth and ground is concerned. But in practical applications, typically if there are non-earthed DC supplies in a piece of equipment, the DC common might be called ground when only the AC side of the power supply is earthed.
BONDING is a whole different matter and the UK and US meanings are quite different. The OP didn't ask about it so I won't elaborate, to avoid confusion.
