New construction in USA. I think that the builder put ceiling fan rated boxes in the ceiling. But when I remove the cover, I see a strange box. Picture attached. It's hard to make out all of the details, because the painter sprayed it.
Have you seen this brand/style box before?
There are two big screw holes near the wire, but they are only 1.5" apart or so. That's not the spread I was expecting and not what my ceiling fan bracket expects.
If this is a ceiling fan box, what are the strong mounting points? Do I need to drill holes or knock out something?
Thank you.
Thank you.
