Discuss Am I Right? L1 and L2 in the Lighting Forum area at ElectriciansForums.net
Not found the instructions for this exact switch, but for 1 way switching one the ones I did find for bg dimmers it was com and L2. What wires have you got at the switch for each one?Hi all, am I right in thinking that line goes to l1's and line switch to L2's?
Thank you
Nope, bloody typical screwfixnope
Isn’t there a connection diagram with it?
I've found with some dimmers they still print the old filament/halogen rating on the back, but if you read the instructions they will work with a lower LED load. Somewhat confusuing, to say the least.Appears to be for a minimum of 60VA. Bit high for a LED dimmer.
It does say check instructions for ratings but not possible if they don't come with instructionsAppears to be for a minimum of 60VA. Bit high for a LED dimmer.
Reply to Am I Right? L1 and L2 in the Lighting Forum area at ElectriciansForums.net
