What is the best signal interface for PC ? | Page 4 | on ElectriciansForums
Guest viewing is limited
Discuss What is the best signal interface for PC ? in the UK Electrical Forum area at ElectriciansForums.net
_q12x_
New York
I mean.... the best and the easiest to use.
I remember back in the 2000's I used a serial interface, I think it was the printer serial port, 25 pins or similar. I believe I even used a mouse port as well, that versatile those systems were back then.
What I could do with it was ... program in C++ and pascal back then, using some imported dll's specific for communication with this serial port, I think it was port 40 or 25? It had a number is all I remember. And I could link to it any transistor base, back then I was working exclusively with BJT's, to light LED's, drive motors, beep some 8ohm I think they were speakers, drive a VU-meter LED bar I think directly from the port pins, without transistors, and also drive IC's , that was the time I learned about multiplexers and expanding the number of output pins. Also input sensors like LDR and buttons. I Loved that kind of easy and straight forward communication.
Today I dont know c++ or pascal anymore, but I am very good in c# and still use VS2010 because its very cool interface and very user friendly overall.
So I want you, to help me first of all, to find the hardware, the port I suppose or something more than a printer port, something more advanced and having more in/out's. The more the better. I want the best you can find for the moment. Best ideas or best adaptations, why not. As long as it's easy and stable to install and use.
And then, the software drivers and possible problems will appear along the way. I can debug a large majority of problems, I grow up debugging computer problems, so I have a 5'th sense for them. Im more concerned about the hardware part and the integration with my win7 that I still run today and my VisualStudio2010 for my c#. I know I still run old software but they are extremely stable and they don't f me up.
Thank you and I'm really curious what you will find for me.
I am not familiar with the microprocessor board and its programming you are using. Seems odd to me that you cannot speed up the bit rate from these outputs. Perhaps some more reading of the manual.
In my version I store the character data in an eeprom and then read it out quickly to drive the 7x5 display.
Now the weather has cooled it is comfortable enough in my shed to restart work to finish off the project. I am slower than you though! You can see slow test scanning in the attached video.
  • FullSizeRender 25.mp4
    6.3 MB
Here, I attach the image I made. See if it is of any help.
You are doing much more harder work than me, you are programming it in hardware. I did it faster because it was in software,and is a big difference.
But yours will be faster and display more better than my results, because the arduino board Im using, has some restrictions I didnt discovered to bypass them, or its just stupidly build like that, with a minimum of 1mHz.
This is a plan for the future, and a serious upgrade. I will have to search and ask around for a solution, to link my entire MCP board to my PC, but NOT using arduino, but something else. I already have some usb to TTL very tiny boards, I think, I have to look and see exactly what I have, but the idea of the upgrade will be that I will put aside the arduino and replace it with something faster in IO department, matching and even better than these MCP's operating fv, which is kind of slow, but fast enough for a lot of stuff. So thats in plan and is a bit more complicated to achieve.
- If anyone else that is reading my progress here, can jump with any idea, please do so. Like @timhoward with Teensy board. More ideas please.
I was unsure and I re-check it with the datasheet of the MCP23017. I got this from it:
High-Speed I2C Interface (MCP23017):
  • 100 kHz
  • 400 kHz
  • 1.7 MHz
I can see diferent values there and they have some specificity I dont know yet. All I know is that this MCP chip, driven from I2C, is doing it at 100kHz.
My math... correct it if you see something wrong, im in the art department:
100 kHz = 100000 cycle/second >> 1cycle is at an interval of 100ms ? Is this right?
Also, this MCP chip has another way of connection:
High-Speed SPI Interface (MCP23S17): - 10 MHz (maximum)
Which I have no idea how I may link it...
The problem is that all the wiring on the boards so far is done for I2C communication ! Not for SPI.
The guy who suggested me these MCP's asked me in the beginning, if speed is a problem, and I said "speed is not a problem" but now... with your project, it starts to be one... damn. But as limited as it is so far, I can reorient to other types of projects. At least I tested some limits so far.
  • [ElectriciansForums.net] What is the best signal interface for PC ?
Exceptionally (for me) is to make it how you make it, only from logic chips like you are making it right now. And is terrible challenging for me to do it like you. But it is remained in my mind to do it like that as well. Not sure when exactly....
I will respond more completely when I have the time and energy and done some research on the 23017 and 23S17 ics.
For now, the period of a repetitive waveform is the inverse of its frequency. So a 100kHz waveform has a period of
1/100000 = 0.00001s or 10 microseconds. A micro second is 0.000001s - one millionth of a second.
- If it helps, for mister @marconi, here is the datasheet for my MCP23017 that I have.
On the very first page you have a summary of what it can do.
Very good math explanation. I like it. I dont do it every day so I tend to forget things. Shame of me. Im mixing colors more often than mixing numbers, haha. Get it? because im a poor artist.
- I start to contemplate the idea of using some faster IC's, like 74HC165 shift registers that @timhoward mentioned already, and most probably more hard to wire in hardware and also much harder to code. Just to have a secondary board. But not 100 I/O pads, just a few, maybe 20 or something. I also remember Teensy board had 40 IO's already and the best one with 58 IO's , which is VERY appealing and also using I2C protocol. Mister @timhoward can confirm it, if is still around.
- Is so disappointing that my Arduino Uno can Not go down under 1ms !!! Ahhhh what a stick in the hearth.
- Also yesterday I received my Arduino Nano board, the replacement for Arduino Uno, and the upgrade for this MCP board I built. I will show some pictures and movie later after I mount everything.
To mister @timhoward if you are still around, can you do a test for me? check your maximum fv that you can get from 1 of your I/O from your Teensy board? And dont read it from its datasheet, but do it in reality and tell me if it stops to 1ms like my arduino uno does, or is actually capable to go down to μs(microseconds) ? Thank you !
q12 Good morning. To aid help me understand your programming could you slow the scan rate so far that I can see how you select an LED for illumination and post a short video. You can see from my video that I scan the LEDs column by column. In the video I have set the data word for each row as (1111111) so that all 7 LEDs in a column are lit when each of the 5 columns is selected. The data word for the columns follows the sequence (10000), (01000), (00100), (00010), (00001), (10000)......
Thus a sequence of 5 pairs of row and column data words, 10 data words in total, allows me to display any arrangement of LEDs on the display. I want to see what you do.
Good morning , where are my manners, right? Hehe.
Remember, this what I do is software programming, but you do it much harder, in hardware !!! Keep this in mind all the time.
Hmmm.... hehe, here is a quick and dirty way of obtaining 1 single led on the matrix, following my already made example.
Just put 5V on pin 3 (with gray) - also dont forget to put resistors !!!! because you will burn the led !!!
and put 0V/ground on pin 11(with gray). Ive also marked with 3red arrows the positions where to put the voltages on which pins.
I will make a more comprehensive explanation for you, but it will take some time, also to make most probably a new drawing, and then the movie and edit it and upload it to yourtube. So until then, at least do this very quick and dirty example here and you will get a procentage of an idea.
So do you select in software one LED at a time by setting one of the line bits and one of the column bits? And then send this data to the MCP23017? Thus to illuminate say all 35 LEDs you have to sequence through 35 pairs of line and column bits (Column, Line). Each data transfer to the MCP23017 has a cycle time Tc - I have yet to find out what this time is. Thus to refresh completely the 35 LEDs will take a time of 35 x Tc - this is the time necessary to send 35 pairs of (Line, Column) messages. This is a slow way to control the 7 x5 display. You could use the 16 bits data outputs in the format ( C1, C2, C3, C4, C5, X, X, X, L1, L2, L3, L4, L5, L6, L7, X) to illuminate a combination of 7 LEDs in one column using one data transfer, and thus the whole display in 5 data transfers - a considerable reduction in data transfer time from 35 Tc to 5 Tc. (The X means not used).
To do this you would have to add some simple hardware to the 7 x 5 display - some transistors and resistors to interpret the 16 bit data word into switches to control the application of 5V and 0V to the LED array. The scanning has to be done column by column to take advantage of the common cathode arrangement inside the array.
Multiplexing in that way is definitely the best way to do it I would say.
Exactly.
Here is the actual program for 'letter A' that I made and presented in the movie.
You may not understand everything but read the entire program anyway and you will get something out of it. I've also put notes what is line and what is column.
(it was imperative to switch to Input everything after each step, with my custom Reset(); method, otherwise it was liting up the entire next line or column)
Remember a line is HIGH because is +5V and a column is LOW because is 0V. So we lit a single line putting +5V on line01(for ex) and 0v on each desired column.
Code:
#include "Arduino.h"                    //core library that contains all of the Arduino’s built-in functions (from 2022)
#include <Adafruit_MCP23X17.h>          //this is Adafruit-MCP23017-Arduino-Library version 2.1.0
Adafruit_MCP23X17 mcp1; //Instantiate mcp1 object
void setup()
  Serial.begin(19200);
  mcp1.begin_I2C(0x20);
  for(int i = 0; i <= 15; i++)
    mcp1.pinMode(i, INPUT);
  for(int i = 0; i <=15; i++)
    mcp1.digitalWrite(i, LOW);
//LED MATRIX DISPLAY - Single LED - one by one
/*  LOGIC:
//Columns----------------------------------------
//  mcp1.digitalWrite(1, LOW); //A1=1=column A
//  mcp1.digitalWrite(10, LOW);//B1=10=column B
//  mcp1.digitalWrite(3, LOW); //A3=3=column C middle
//  mcp1.digitalWrite(11, LOW);//B2=11=column C middle
//  mcp1.digitalWrite(4, LOW); //A4=4=column D
//  mcp1.digitalWrite(13, LOW);//B6=13=column E
//Lines----------------------------------------
//  mcp1.digitalWrite(5, HIGH);//Line1
//  mcp1.digitalWrite(0, HIGH);//Line2
//  mcp1.digitalWrite(6, HIGH);//Line3
//  mcp1.digitalWrite(2, HIGH);//Line4
//  mcp1.digitalWrite(12, HIGH);//Line4
// mcp1.digitalWrite(8, HIGH);//Line5
//  mcp1.digitalWrite(14, HIGH);//Line6
//  mcp1.digitalWrite(9, HIGH);//Line7
void Reset()
int dly = 1;
void chr_A()
  //line1
 mcp1.pinMode(5, OUTPUT);   //line
 mcp1.pinMode(10, OUTPUT);   //column
 mcp1.pinMode(3, OUTPUT);   //column
 mcp1.pinMode(4, OUTPUT);   //column
 delay(dly);
 Reset();
  //line2
 mcp1.pinMode(0, OUTPUT);   //line
 mcp1.pinMode(1, OUTPUT);   //column
 mcp1.pinMode(13, OUTPUT);   //column
 delay(dly);
 Reset();
  //line3
 mcp1.pinMode(6, OUTPUT);   //line
 delay(dly);
 Reset();
  //line4-midle
 mcp1.pinMode(2, OUTPUT);   //line
 delay(dly);
 Reset();
  //line5
 mcp1.pinMode(8, OUTPUT);   //line
 delay(dly);
 Reset();
  //line6
 mcp1.pinMode(14, OUTPUT);   //line
 delay(dly);
 Reset();
  //line7
 mcp1.pinMode(9, OUTPUT);   //line
 delay(dly);
 Reset();
void loop()
 chr_A();
Reply to What is the best signal interface for PC ? in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
