Dodgy trade pictures for your amusement! - 1 Million Views! | Page 253 | on ElectriciansForums
Darkwood
West Yorkshire
My own dodgy pic…
Only socket circuit is dismantled to find faulting section. CU other end of house a long way away. All 18v batteries flat. Needed a multi-tool.
Had a mains multi-tool with me. No extension lead.
Options were rigging up builders board and running 16A cables….or…..misusing some kit…
(The DIY adapter dates back several years to a Robin plug in RCD tester and wanting to use probes to test an RCBO)
My own dodgy pic. Been testing an empty school with a non time delayed 100ma main switch rcd on TT. It was being a right royal pain in the --- so I took it out of the equation, safe me thinks so.View attachment 100878
OK I will bite, what are the Green/Yellows by passing the RCD for.
To stop nuisance tripping whilst testing. It is not time delayed and it kept tripping before the rcbos plus it made testing of the non rcbo circuits easier.
A few pictures from today’s encounters
A garden install of consumer unit and double socket🤣(it’s been tripping out the house, wonder why)
and another cable repair job
  • [ElectriciansForums.net] Dodgy trade pictures for your amusement! - 1 Million Views!
Really odd set up the cabling went from the consumer unit over the fence and into the garage behind supplying lighting and another double socket in 1mm t&e which the owner has been plugging a 13A EV car charging lead into 🙄
I bet it's an old guy who did that.
There's a gas pipe going into that socket!
People have some weird ideas. Not much work on so give the lads paint and brushes to make things look a bit tidier and that's the result....It doesn't cover up the sh8te standard of work of the additions and alterations, though. It's a few years back now but some RCD sockets had to be changed after being painted over.
I do some work at a couple sport centres and when it has been quiet instead of the staff sitting around picking their ears they have been painting all the door frames , conduits , surface trunkings and ever light switches and sockets BLUE to match the walls 🙃
I hate it when tube and trunking is painted the same as the wall..... trunking and tube needs to stand out....its a work of art
When recently on a day trip to York, I amazed my daughters by requesting a visit to Urban Outfitters.
"Why????" they said. "It's the most amazing maze of galv conduit I've ever seen, I could stare at it all day...." I replied.
Sadly I don't have a photo and can't find one online.
