Sangamo M5 replacement timer | on ElectriciansForums
Discuss Sangamo M5 replacement timer in the Central Heating Systems area at ElectriciansForums.net
pirate
Supporter
Glasgow
I have been asked to find a replacement timer for a Sangamo M5. I've done some searching, but frankly came to no obvious conclusion. Not my usual area of work, so I hope someone with recent experience can point me at a suitable model.
M5 is a basic 2 channel programmer, so virtually any 2 channel programmer on the market will replace it. Or are you looking for a mechanical rotary dial, rather than electronic?
Thanks for the replies, much appreciated.
Yes, it's a basic 2 channel...I just suspect the base panel will be so old there's no direct replacement, but I'll source a simple new one and wire accordingly.
The current one looks like this:
[ElectriciansForums.net] Sangamo M5 replacement timer
Reply to Sangamo M5 replacement timer in the Central Heating Systems area at ElectriciansForums.net
That doesn't make sense it is a completely new timer so needs connecting as per the instructions for this unit. Has the safety cut out on the...
Hello Brianmoooore, Thanks for yor reply - Sorry that I did not see your message until today - the Forum replies notification emails about your...
