Running a couple new sockets from mains | on ElectriciansForums
Discuss Running a couple new sockets from mains in the UK Electrical Forum area at ElectriciansForums.net
Uk
Hi everyone
Just looking for a little advise on if my plan to run this spur is okay I’ve drawn a diagram in hopes to make my expiation simpler
The MS square is the main socket which has not been tampered with
The F is a 13 amp fuse spur
And the S are the additional sockets which I plan to add in the exact same wiring example
I’m using 2.5mm twin core and earth cable
Edit: two of them will be single sockets the other will be a double socket
[ElectriciansForums.net] Running a couple new sockets from mains
Is the existing socket definitely on a ring circuit?
Yes definitely a ring circuit there’s two wires that go into the main socket and dose appear to have any previous tampering with
Out of interest, does the drawing show intended cable routes and, if so, will cables be in a wall or on its surface?
The cables will be router under the floor and some behind walls but yes the wiring diagram is roughly how I intended to do it
You can't run buried cables diagonally. Have a Google of prescribed zones.
The fact that it has two wires does not necessarily mean it is on a ring. Although it could well do.
Pretty confident that the socket is connect to ring main I can add some photos if it would help as for the diagonal cable I've already got a channel for where the cable will go
You asked if your plan was okay. If it involves running cables diagonally in a wall, then it is not okay.
Bear in mind that this arrangement will be limited to a combined load of 13A between all of the new sockets.
If the Chanel is diagonal across the wall, I would not use it.
idealy, you would extend the ring instead of adding a fused spur and a couple of sockets from there.
Sorry don't think I explained it properly the straight wires there run through the walls the digagonal cables are under the floor
Not sure if this will help but here are photos from the main socket
  • [ElectriciansForums.net] Running a couple new sockets from mains
Two cables into a socket is what I would expect to find on both a RFC and a radial circuit, so that means nothing. The rating of the protective device (fuse, MCB or RCBO) will be a better clue.
One cable would indicate a spur from a RFC or the end of a radial circuit. Two indicate nothing other than it is not either of these.
Can you explain the last bit to me like I’m an idiot please lol 🤣
@nicebutdim was just making you aware that the 3 extra sockets you are adding can only handle 13A in total.
You have added a 13A fused spur at the beginning so the fuse will blow if you add large current drawing items to the 3 extra sockets.
Reply to Running a couple new sockets from mains in the UK Electrical Forum area at ElectriciansForums.net
This is an interesting issue. I agree with you however I took this to task with a scam inspector some years ago and we agreed to disagree that...
In Theory that’s a good argument but if you will be adding or moving switches or sockets or adding lights you’ll more than likely end up needing a...
