Hi everyone
Just looking for a little advise on if my plan to run this spur is okay I’ve drawn a diagram in hopes to make my expiation simpler
The MS square is the main socket which has not been tampered with
The F is a 13 amp fuse spur
And the S are the additional sockets which I plan to add in the exact same wiring example
I’m using 2.5mm twin core and earth cable
Edit: two of them will be single sockets the other will be a double socket
