2365 design drawing level 3 | on ElectriciansForums
Discuss 2365 design drawing level 3 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
uk
Help! Level 3 project here but I cant make head nor tails about what to do next. Can anyone give some advice please because I'm so lost!
  • [ElectriciansForums.net] 2365 design drawing level 3
Hello,
Not to worry it's easy. On drawing 1 you have drawn the sockets I would probably use a ruler to keep lines straight and make it neat. Just need to put a light in the center of the room and one more in the toilet and wire it up from DB. let me know how you get on.
Upvote 0
Can someone email me the example of they project please , I'm completely lost with it and paid quite a bit of money for the course to fail any help will be much appreciated
[email protected]
I don't think anyone will send you their hard work to be honest.
If you are completely lost then you need to seek help - you've paid for the course.
Upvote 0
Use the below to layout your calculations (in my case it was for the 8202-30) and cite your sources. There's a document in our downloads section with similar walk-through steps - Cable Calculations Sheet Updated for 2022 - https://www.electriciansforums.net/resources/cable-calculations-sheet-updated-for-2022.207/
In terms of routing that will be down to you. My advice would be to get some A3/A4 clear acetates and plan your routes on them, this gives the advantage of easily distinguishibg the circuits and routes (as you have 1 per sheet), once you're happy with them overlay them on your A3/A4 drawing and staple one side.
I male the assumption that it's the calculations you're are struggling with here?
Upvote 0
Hi pal, Amy tips for the design
Upvote 0
I'd scan that copy and paste it into Word and use the tools to draw lines & text boxes to keep it neat. there seems to be a few of you on here now!
Upvote 0
Reply to 2365 design drawing level 3 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
If you are using Zdb you do not add on Ze as that is already incorporated into Zdb.
Anybody who finds the best electrical training videos please add them to the forum in the training category here please. Copy and paste the URL to...
Electrical Courses
