Housebashing wiring helped | Page 2 | on ElectriciansForums
Discuss Housebashing wiring helped in the UK Electrical Forum area at ElectriciansForums.net
Shpark
Chester
Hi all, not a housebasher here, so don’t hate. Wiring my house and need advice. Want to mount the CCU just below the ceiling and bring the cables from the floor above. How do a nicely bring the cable off of the beam so they’re on the wall and then will go into the back of the fuse board? Pics attached
I haven’t contemplated this a great deal since asking as been been busy with work, but up to now I have thought to do as per the pic. Bring cables off joist onto brick. Into safe zone at top of ceiling height and onto adjacent wall, down and into CU. The reason I’m mounting on this wall is due to space and aesthetic, but more so that the meter tails pass through direct behind wall to meter in box outside. Also the box will be lower down now.
  • [ElectriciansForums.net] Housebashing wiring helped
Although you don't have to install to the heights stipulated in part m your work shouldn't make it any worse. It appears like it would be much easier to put it lower and run 50 x 100 trunking, depending on the room either chase the wall so you're behind the joist or use an internal 90 to run a small bit on the ceiling.
Dusty might sell you some black and red if you're not part p...
I’m still using DB…
Maybe the guys I was an apprentice to had it all wrong.
They told me a CU … consumer unit… was domestic. Where there is a consumer, that lives in the house.
A DB distribution board was used industrial or non-domestic situation where there was a main board which then distributed out to other sub mains within a large installation. Could be 3P or 1P.
If my customer is past pension age, I still ask “where’s the fusebox?” Because that’s what they’ve always known it as.
If you can put cables (and tails as needed) in some trunking it would make any future changes / additions / repairs far easier, also less chance of any accidents if trunking is somehow visible but "aesthetically acceptable".
Distribution board (DB) is a generic term for all of these. A consumer unit is a particular type of DB intended for use by ordinary persons (DBO), which is type tested and single phase with a double pole main switch. As such it is not incorrect to refer to a CU as a DB, although not all DBs are CUs.
EDIT: Much as @pc1966 has stated.
In rural Europe thee phase in Domestic properties is not unusual and they call the container box by every conceivable variation, even in the regulations they confuse the issue, but for all intents and purposes does it matter, we all know what we mean. 😇
I think this intriguing study explains it all.
I think most folks still think "fuse box" even though fuses have not been the norm for many years now.
I believe a CU is defined as a DB that meets specific type approval for domestic use, so DB is a more generic term.
I posted similar thoughts in another thread, some time back.
Regardless of everything, 'consumer unit' has no meaning to anyone outside the trade and is a daft term.
While incorrect, 'fusebox' has meaning for domestic customers and its use in conversation is understood by all involved. DB covers all types of distribution board and is understood by everyone in the trade.
I gather that CCU/CU was introduced as a term for domestic DBs, to replace incorrect use of 'fusebox', but it's a nonsense term and I refuse to use it unless absolutely necessary. I won't encourage the madness of others 😁
K
What is the room where your going to locate CU/CCU/DB/FuseBox? Could you run circuits/tails in plastic trunking?
You do need to think about Notification, which Country do you live in?
hmm ideally not. It’s in the hall in plain sight. Not tucked away anywhere nice.
I live in England. I’ll probs get a part p spark round before I run anything and then get them to cert it
I have to agree with this. 'consumer unit' is as vague as it gets, and 9 out of 10 customers don't have a clue what it is.
Although I use the terms Fusebox and consumer unit. The majority of the time I call it a board.
IE.. Where’s your board located? What RCBO’s will fit this board, look at the state of that board, who the F… still installs split load boards these days? Etc…
Reply to Housebashing wiring helped in the UK Electrical Forum area at ElectriciansForums.net
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
L
Just doing some thread admin :)
Hopefully you've sorted this by now, but for future readers I'll respond anyway. There is no way to properly operate this unless as you suggested...
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
