Discuss What is the incoming Voltage Before and After the Service Fuse? in the UK Electrical Forum area at ElectriciansForums.net
Two main things came to my mind when I saw that.tim, can you shed light on what I should be aware of?
IMO that is a dedicated neutral block that cannot take a fuse. On these Series 3's they are similar in style but different shapes; the neutral block is flatter.That service head design is a type that could incorporate a fuse on the Neutral as well as on the incoming phase.
Oh no! Not that Faron Young song...!!!I hope that picture on the OP is a textbook example and not a board being worked on….
And what you doing asking questions at 4 in the morning?
Reply to What is the incoming Voltage Before and After the Service Fuse? in the UK Electrical Forum area at ElectriciansForums.net
