Does this henley block on the incoming tails of TT have a fuse in? | on ElectriciansForums
Discuss Does this henley block on the incoming tails of TT have a fuse in? in the UK Electrical Forum area at ElectriciansForums.net
NN14 4UH
[ElectriciansForums.net] Does this henley block on the incoming tails of TT have a fuse in?
Well that’s not confusing in any way…. Brown used for line and neutral and then disappears behind the board.
Just asking for a polarity mix up.
Those browns are an old outer sheath colour,more a dark maroon really. the basic insulation will be red and black inside.
0.44 Meg ohm is 440000 ohms.
You are of course correct. I Think i'm confusing myself. I cannot see any bonding conductors in the CU, yet when I get my wander lead out and test from the only earth conductor in there to the stopcock pipework and gas meter I get 0.00 Ω on each despite not being able to see any bonding conductors or earth clamps anywhere. Also when testing the ZE I was looking at my Megger testing a disconected main earth cable to earth electrode and got a reading of 0.44mΩ. I had in my head Ohms. This is of course megaohms... I haven't seen a TT system for a few years and I think I need to read up a bit. Thanks for your help..
This will be via the cpcs of cables to the boiler, immersion heater, etc.
Reply to Does this henley block on the incoming tails of TT have a fuse in? in the UK Electrical Forum area at ElectriciansForums.net
Obviously you need to check the means of earthing, Ze, and polarity no matter what for the EIC. As above, if anything looks dodgy then EICR is a...
Thanks for the replies, I appreciate it.
More important than torque, is to settle the strands of the cable as you tighten the screws. Pity that a few more meter installers aren't familiar...
even allowing for diversity this sounds a bit tight for a 100 amp supply, can you tell us what the existing circuits actually have connected to...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
