Does this henley block on the incoming tails of TT have a fuse in? | on ElectriciansForums
Guest viewing is limited
Discuss Does this henley block on the incoming tails of TT have a fuse in? in the UK Electrical Forum area at ElectriciansForums.net
NN14 4UH
[ElectriciansForums.net] Does this henley block on the incoming tails of TT have a fuse in?
Well that’s not confusing in any way…. Brown used for line and neutral and then disappears behind the board.
Just asking for a polarity mix up.
Those browns are an old outer sheath colour,more a dark maroon really. the basic insulation will be red and black inside.
0.44 Meg ohm is 440000 ohms.
You are of course correct. I Think i'm confusing myself. I cannot see any bonding conductors in the CU, yet when I get my wander lead out and test from the only earth conductor in there to the stopcock pipework and gas meter I get 0.00 Ω on each despite not being able to see any bonding conductors or earth clamps anywhere. Also when testing the ZE I was looking at my Megger testing a disconected main earth cable to earth electrode and got a reading of 0.44mΩ. I had in my head Ohms. This is of course megaohms... I haven't seen a TT system for a few years and I think I need to read up a bit. Thanks for your help..
Reply to Does this henley block on the incoming tails of TT have a fuse in? in the UK Electrical Forum area at ElectriciansForums.net
This was posted this week, on topic ....... https://niceic.com/newsletter/omission-of-overload-protection/?dm_i=7G1W,7GCE,K4L2A,WHET,1
Obviously you need to check the means of earthing, Ze, and polarity no matter what for the EIC. As above, if anything looks dodgy then EICR is a...
