EICR Test Fail, before and after | Page 2 | on ElectriciansForums
Discuss EICR Test Fail, before and after in the UK Electrical Forum area at ElectriciansForums.net
London
Hi, recently had an EICR test done by 'Landlord Certificates' which failed due to circuite 3 having two radial circuits into a single 32amp MCB, they advised splitting it into two 20amp MCB's and quoted £174 including EICR certificate. The Electrian appears to have simply taken out the 32amp MCB's and put in a 20amp and 16amp. Was the original actually a fail? And is what the Electrician has done now acceptable?
[ElectriciansForums.net] EICR Test Fail, before and after
The best one I had recently was 2 circuits, 1 ring and 1 16 A radial but one leg of the ring was in the 32A along with the shed radial and the other leg of the ring was in the 16A MCB marked shed supply. Not only that the board was a mismatch of MCB's and the only way they could get some to fit was put them in upside down so when they were switched on they were all pointing different ways, oh and the board was mounted sideways.
That was fun trying to get the power to go off, had to switch the main switch off and then sit down and try and work out what on earth was going on.
A side ways mounted board with numerous makes of breakers with some mounted upside down and some sharing the same circuit.
That is some kind of special
So sorry to resurrect this again, I still haven't got it resolved so I'm going to give up on the current Electrician and find a new one, he was supposed to come fix it but never turned up.
Anyway I bought one of those socket testers off Amazon just to see if there were any obvious faults and discovered something I think is odd.
On the image below I have labelled up the CU -
This is how it's labelled on the cover-
Circuit 1 - Cooker
Circuit 2 - Central Heating, NOTE: when turned off the boiler stays on
Circuit 3 - One Double socket in Bedroom 2, NOTE: when turned off boiler goes off too
Circuit 4 - Two Double sockets in living room, Two double sockets in Bedroom 1, and One Double Socket in Bedroom 2
Circuit 5 - Two double sockets in same cupboard as CU, and two Double sockets in Kitchen
Circuit 6 - Lights
Circuit 7 - Extractor Fan
Circuit 8 - Two Double sockets in Hallway
So it seems circuit 3 is a ring that serves just one socket, and the boiler. No clue what wire is in the central heating circuit, turning it off doesn't seem to turn anything off.
I'd like to get this tidied up and safe, plus I still need an EICR, when looking for a new electrician what do I tell them? It's not a full rewire is it?
It doesn't need to look like some piece of art but I'd like it to be of a standard where I'm not embarrassed to post a photo of it. Can I assume circuit 3 just needs to be turned into a radial, the boiler put into circuit 2, and a 32amp MCB added back to circuit 4, and then a tidy up?
Thanks so much for all the info posted, the electrician that did this was giving me the run-around, I was able to have a basic discussion about rings and radials and he backed down and admitted a mistake was made.
Cheers
Circuit 1 - Cooker
Circuit 6 - Lights
Cheers
Is circuit 3 a ring ? Or is it already a pair of radials ?
Is the feed to the boiler via a fcu ?
What type of boiler is it ?
Do you have an immersion tank heater ?
The chap who come to do the EICR said 3 was a ring that had lost continuity, but I don't think he can be relied upon.
Yes Boiler has FCU.
Combi boiler - no tank, it was fitted last year by BG
Sorry not much to add except to say those terminations are so bad they make my eyes bleed. Exposed copper all over the place.
I think you need a new electrician that comes recommended. If you don't know any from family or friends then at least you could look up NICEIC etc for a registered electrician from your area.
Reply to EICR Test Fail, before and after in the UK Electrical Forum area at ElectriciansForums.net
There is one reason to have an inspection every three years instead of the five. It’s more work and money for them 😁😁
It could be there is some other reason for not sending the report, for example they lost the measurements (assuming they did actually make some...
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
If carrying out an EICR it's unrealistic to expect that every unusual occurence can be fully investigated, so surely you'd code accordingly, makes...
nicebutdim
N
Thanks. I presume it’s okay to be pedantic given that I’m not working with 9V batteries. To be clear, I’ll double, triple and quadruple check...
