Hi guys, long time lurker first time poster.
I have an SWA 3 core armoured cable buried that runs to my back garden. This originally serviced an old delapitated workshop from the previous home owner. The workshop was removed, SWA armoured cable cut and left available to be reused in the back garden or hooked up to new shed or garage.
I’ve decided to use it as a simple feed to power an outdoor double socket for occasional electrical mower/strimmer and outdoor lighting
I was always under the impression it fed straight to our main fuse box, labelled under “garage” which is RCD protected. This has always had the garage breaker off ever since the workshop was removed.
I’ve switched the fuse breaker on to test that the cable is live with a multimeter and it’s showing as dead? Other than the fuse itself, is there anything else that could cause it to be dead?
I’ve checked for any switches and there is one under the fuse box that I thought might control the feed but it’s still dead with that switched on or off.
Any help would be great!
Will provide pics below.
