R7S LED retrofit not working | on ElectriciansForums
Discuss R7S LED retrofit not working in the Lighting Forum area at ElectriciansForums.net
joliver
London UK
Hi all, I am trying to replace my halogen wall uplights (230W, 240V, R7S, 114mm) with LED but so far no luck. I've tried both of the below LEDs but they do not illuminate when the switch is turned on. The halogen bulbs work just fine. Am I missing something?
Philips CorePro 17.5W 118mm Dimmable LED R7S
ProLite 10W 118mm Non-Dimmable LED R7S
Any thoughts would be appreciated!
  • [ElectriciansForums.net] R7S LED retrofit not working
Are the contacts in the old fittings nice and clean - no oxide film or corrosion?
Might be worth giving them a scrub with a Scotchbrite pad or equivalent if you can get in there!
SOLVED
So it turns out the reflective backing was just barely blocking the chunky LED from fitting properly against the contacts. Not enough for me to notice at first. I crimped the backing away slightly to allow the LED to make proper contact and now they work great. Thank you SJD and Avo for your help!
Reply to R7S LED retrofit not working in the Lighting Forum area at ElectriciansForums.net
    • Friendly
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
