Upside Down UK Plug Socket - Is This Normal/Ok? | on ElectriciansForums
Discuss Upside Down UK Plug Socket - Is This Normal/Ok? in the UK Electrical Forum area at ElectriciansForums.net
Grimers
Exeter, UK
Hi all,
Just recently moved into a renovated house in the UK where a desk is quite high, so the plug socket above it has had to be put in upside down! Other than a bad case of OCD, is this normal/ok?
Please see attached photo.
[ElectriciansForums.net] Upside Down UK Plug Socket - Is This Normal/Ok?
Cheers,
Will
As it is just one plug socket above a fitted desk I would persoanlly just leave it as is and live with it upside down
Whats to say its not the correct way up and we have just been fitting sockets the wrong way up for decades
Thank you for your quick replies, all. Probably is best to just leave it as apparently trying to move it up and then fix the wall afterwards may look even worse! I will message the electrician we know and see what he says (he put the electrics in and is very good). Cheers!
It's going to look a bit crap with the wires coming out of the top in a loop. But that's just aesthetics.
If it really is setting your OCD off into hyper-drive , you could get the sparks to blank off the socket and cut in a new sockets directly above thus avoiding haveing to spend a hour trying to patch any damage attempting to move the old socket up 2 inches
Another crazy idea : M2 grid frame, 2 USB charger modules, and a spur down to socket(s) under the desk.
Yep, it was bought from Howdens and their desk heights are higher than the standard (not sure on the complete details as someone else dealt with it). We worked out the height of the socket assuming standard height, but no they didn’t tell us that the one they provided was higher! We probably should have confirmed, but it was too late once we had painted ready for the desk to be installed…
By the way, there are plenty of sockets below the desk, so we can always use a cable hole and drop the cables down below it if it's a problem, but was just wondering if there was an easy solution to fix this (maybe snowhead's idea is the way to go). Has anyone else come across/installed sockets this way round before?
If keeping the socket upside down, I recommended putting something under it to catch the electricity that falls out.
No need to. It'll just form a puddle on the top of the desk. If the desk wasn't there then I agree that you would need something to catch it. I would use a plastic takeaway container. Don't use one of the foil ones as you could get a shock if you didn't ground it before emptying.
Foil containers should be grounded anyway. Surprised you aren't aware of that. :)
Is this really ok? I’m concerned that if we use it then there could be issues.
Provided no cables are strained, etc, it is fine, just unconventional. FYI the sockets on some trains are that way for the same sort of reasons, just labelled to explain it!
If it worries you then a lower desk, or some spacer so it is not hard against the wall, would allow a conventional solution.
Thanks, unfortunately we can’t lower the desk as it’s fixed. We will sort it one way or another!
Reply to Upside Down UK Plug Socket - Is This Normal/Ok? in the UK Electrical Forum area at ElectriciansForums.net
Thank you for fast response. The reason I asked is because I had read elsewhere online: "Electric ovens have a wattage rating that tells you how...
What is the distance from the point outside the house to the shed?
seems to be a big song and dance over this one guys, this is bottom basement stuff and seriously I cannot believe one the thread was put up and...
Recommend this: Electricians Guide to Inspection and Testing Book -...
In all likelehood, no different. The RCD on the left is looking for electricity that is going missing in action. If the total missing reached...
