Guest viewing is limited
View the thread, titled "Upside Down UK Plug Socket - Is This Normal/Ok?" which is posted in UK Electrical Forum on Electricians Forums.
Hi all,
Just recently moved into a renovated house in the UK where a desk is quite high, so the plug socket above it has had to be put in upside down! Other than a bad case of OCD, is this normal/ok?
Please see attached photo.
Cheers,
Will
If keeping the socket upside down, I recommended putting something under it to catch the electricity that falls out.
No need to. It'll just form a puddle on the top of the desk. If the desk wasn't there then I agree that you would need something to catch it. I would use a plastic takeaway container. Don't use one of the foil ones as you could get a shock if you didn't ground it before emptying.
Foil containers should be grounded anyway. Surprised you aren't aware of that. :)
Is this really ok? I’m concerned that if we use it then there could be issues.
Provided no cables are strained, etc, it is fine, just unconventional. FYI the sockets on some trains are that way for the same sort of reasons, just labelled to explain it!
If it worries you then a lower desk, or some spacer so it is not hard against the wall, would allow a conventional solution.
Thanks, unfortunately we can’t lower the desk as it’s fixed. We will sort it one way or another!
Well, the socket seems to work fine and have actually found that there is less strain on the cables with the socket orientated this way. The socket is hidden by a PC monitor now, so at least we don't have to look at it!
only problem could be that the electriccs leak down through grVITY TO THE EARTH PIN, THUS CAUSU=ING YOUR rcd TO TRIP.
Reply to the thread, titled "Upside Down UK Plug Socket - Is This Normal/Ok?" which is posted in UK Electrical Forum on Electricians Forums.
