Cycles per second meter | on ElectriciansForums
Discuss Cycles per second meter in the UK Electrical Forum area at ElectriciansForums.net
pikis
SE
Hello fellow electricians,
Would anyone know how to connect a Nalder Bros & Thompson LTD London, please?
~The BS 89 is a tough book to obtain.
I wired the unit according to this diagram, which is the closest what I have.
[ElectriciansForums.net] Cycles per second meter
This is the beauty in pics:[ElectriciansForums.net] Cycles per second meter[ElectriciansForums.net] Cycles per second meter[ElectriciansForums.net] Cycles per second meter
And this is what I thought to do next, plug it into mains:[ElectriciansForums.net] Cycles per second meter
The yellow and blue wires, (now replaced with brown and blue), where do they go? series to load on live wire or the way I have it could work too?
I hope you find this interesting and would be so kind to reply.
Thank you very much in advance
Pikis
  • [ElectriciansForums.net] Cycles per second meter
Pikis- I strongly recommend you do not apply power yet especially from the mains because we need to confirm the technology of the meter in front of you and its designed operating voltage.
I think the wiring diagram you showed, which is for a moving iron mechanism type meter, is not what is in front of you.
The meter in front of you I think is a moving coil meter mechanism which uses direct current. There are hints to this because I believe the two blue cylindrical components to be metal type bridge rectifiers to turn ac in to dc to drive their respective meter coil.
Metal rectifier - Wikipedia - https://en.wikipedia.org/wiki/Metal_rectifier
The meter I think uses the ratio metric technique - see
http://sves.org.in/ecap/Resources/Frequency meters_74.pdf
To help, could you first carefully draw out what is connected to what please. The circuit diagram at the ratio meter slide is a guide to what I suspect you will draw.
Thank you both very much!
Oh it works, this time it shows 60 Hz,and UK cities' setup is ususally 50 Hz, so it's likely reading incorrect.
Could calibration, replacing part help (finding an original rare)? Can someone please point at where to look?
~It was the owner who plugged it to mains a few moments ago~
Warm Regards
I should point out that the meter connected as it is by its two terminals to a lead and 13A plug does not meet today's safety standards. Those terminals are exposed live parts. Similarly, if the meter mechanism is made of metal and its front face too then it could potentially be live. What is your intention for the meter once you have it working? You can buy safe plug in frequency meters such as this one:
https://www.amazon.co.uk/Monitor-Ba...3&psc=1&mcid=b0886befc02a36868851baac5fb20dde
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Reply to Cycles per second meter in the UK Electrical Forum area at ElectriciansForums.net
