HMO regulations for electrics | on ElectriciansForums
Discuss HMO regulations for electrics in the UK Electrical Forum area at ElectriciansForums.net
London
Is this acceptable for a flat in an eight flat HMO there are three floors.
  • [ElectriciansForums.net] HMO regulations for electrics
  • IMG_4774.mov
    46.9 MB
Probably not, but there’s not enough there to make an opinion.
If that extension lead is powering the storage heater, then that’s wrong.
Trunking through a bathroom is just untidy. Fan upside down, no issue, just no following manufacturers instructions.
There’s nothing there that is 100% dangerous. There’s not enough evidence to a comment on that.
The plug is not wired safely and must be rewired. Although as littlespark says, the arrangement is likely not suitable for that heater anyway.
The armoured cable to the consumer unit could do with a cleat.
Welcome to the forum.
I've merged the two threads into one and just popped it into thw right category.
The worst kind of landlords are all now heading into the HMO world. Its huge money for them with very little control from the councils in real life .
Reply to HMO regulations for electrics in the UK Electrical Forum area at ElectriciansForums.net
if the 3 spaces with charge points are always allocated to the same 3 flats, surely the easiest way is to run the supply to the load side of the...
IMO Better to do something about those ignoring regulations first! Current system is like having a speed limit but not enforcing anyone without a...
