Light wiring | on ElectriciansForums
Discuss Light wiring in the UK Electrical Forum area at ElectriciansForums.net
davet24
Wales
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the middle ones where there is only 2 reds would the black wire go here ( landing light not working ) dont think i have seen this before and a bit reluctant to connect it here
Going to need a clear picture.
[ElectriciansForums.net] Light wiring
It looks like Red L, Black SL reversed but if other lights are affected neutral may have been broken......someone's had a go by the looks. It needs investigation IMO, the twin and earths may not be correctly identified.
Reply to Light wiring in the UK Electrical Forum area at ElectriciansForums.net
Yes still see the odd red white and blue out in the wild, usually without cpc, iirc that colour code was only used for a short time...could be...
Thank you so much for your help with this light work perfect now thank you again much appreciated
