UK Light wiring
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the middle ones where there is only 2 reds would the black wire go here ( landing light not working ) dont think i have seen this before and a bit reluctant to connect it here
Going to need a clear picture.
It looks like Red L, Black SL reversed but if other lights are affected neutral may have been broken......someone's had a go by the looks. It needs investigation IMO, the twin and earths may not be correctly identified.
That red almost certainly went in the middle originally. I suspect if other lights are affected it is the screw lose at the loop.
davet24,
davet24,
TrueNAS JBOD Storage Server
