Currently reading:
3AMP socket?
Discuss 3AMP socket? in the UK Electrical Forum area at ElectriciansForums.net
Adawkins1
Hey all,
Can anyone tell what I can use this socket/if it is safe to use?
No idea what the 3amp restriction is. Seems to run off the loft lighting circuit.
i'd guess someone has labelled it as 3 Amp because the cable supplying it is undersized or maybe it's supplied from a light circuit. It's not possible to determine safety of the outlet just from the picture but I'd suggest you don't use it.
This thread hasn't been replied to for 14 days, so replying to this one may not get a response. Post a new thread instead.
Reply to 3AMP socket? in the UK Electrical Forum area at ElectriciansForums.net
