3AMP socket? | on ElectriciansForums
Discuss 3AMP socket? in the UK Electrical Forum area at ElectriciansForums.net
Adawkins1
Yorkshire
Hey all,
Can anyone tell what I can use this socket/if it is safe to use?
No idea what the 3amp restriction is. Seems to run off the loft lighting circuit.
  • [ElectriciansForums.net] 3AMP socket?
i'd guess someone has labelled it as 3 Amp because the cable supplying it is undersized or maybe it's supplied from a light circuit. It's not possible to determine safety of the outlet just from the picture but I'd suggest you don't use it.
Reply to 3AMP socket? in the UK Electrical Forum area at ElectriciansForums.net
Are you sure the existing outside socket is on the ring, and not already a spur? I tend to place a switch fuse on the ring inside so that the...
Outside socket… ok. But you say the fcu for boiler is beside the outside socket… is the boiler outside too? FCU’s have an IN and an OUT… the OUT...
