What is this 1970s fuseboard? | on ElectriciansForums
Discuss What is this 1970s fuseboard? in the UK Electrical Forum area at ElectriciansForums.net
London
Hi, went on a job today, to swap over an oven. On arrival, the homeowner was on a work video call and I couldn't isolate the circuit as there were no labels on the fuseboard. Worse, there was no local isolator for the oven so I had to walk off the job as it needed a new quote etc. (My Job Quote).
Anyway, I was confronted by this fuseboard thing with switches. I have come across BS3036 and plug in MCBs but not this. Are they a plug in replacement and pull out like the bladed fuses?
[ElectriciansForums.net] What is this 1970s fuseboard?
Crabtree c50
As above, Crabtree circuit breakers, the values for each circuit are marked on the ends of the levers. The photo shows the ON & OFF positions. Nothing to pull out or plug in!
You can see there are three 30A circuits (typically cooker & 2 socket circuits), one 15A circuit (typically immersion and whatever has been added to it such as a shower pump or new boiler), and two 5A lighting circuits (normally Up and Down).
So if the oven is not connected to the cooker circuit, likely it will instead be on the socket circuit that supplies the kitchen. If not properly labelled, sometimes the circuits get marked on the outside of the flap or a loose bit of card.
Very robust circuit breakers, John Ward has done some content on them on Youtube, only potential pitfall is relatively low breaking capacity (3KA if memory serves) shouldn't be a problem in nearly all cases, although difficulty in providing RCD protection would see that board replaced in the event of significant works
Reply to What is this 1970s fuseboard? in the UK Electrical Forum area at ElectriciansForums.net
Ouch. Danger notice to customer in my book.
Something to do with the plastic notes, and the way you hold it to make it rigid, amplifies the vibration somehow. Might only work with Scottish...
His five point plan: On 16 April 1973, Gaddafi proclaimed the start of a "Popular Revolution" in a speech at Zuwarah.[151] He initiated this with...
7K
If you're quick enough with the megger after the RCD trips, you will see a rapidly increasing resistance. The resistance when measured cold is...
4K
I have a similar issue. In my case part of the problem is the cumulative residual current across different circuits protected by a single rod. I...
