Hi all. I've just bought a cupboard push switch to turn the cupboard lights on when I open the door.
It's just a single in-line switch in a plastic housing.
The switch will be switching 240v mains taken from the lighting circuit but what are you thoughts... should I wire and switch the live or the neutral wire to break/connect the circuit?
Cheers. Steve.
Cheers. Steve.
