Hi all. I've just bought a cupboard push switch to turn the cupboard lights on when I open the door.
It's just a single in-line switch in a plastic housing.
The switch will be switching 240v mains taken from the lighting circuit but what are you thoughts... should I wire and switch the live or the neutral wire to break/connect the circuit?
Cheers. Steve.
Cheers. Steve.
Always switch the Live, otherwise you would leave a Live at the light fitting when the switch is turned off.
How are you planning to connect this switch as they very often have exposed terminals?
Essex
Cupboard lighting push switch
Steviecuk,
Steviecuk,
