I have a Megger MFT 1721 everything works fine the button that lights up the screen and the switch button doesn't work. | on ElectriciansForums
Discuss I have a Megger MFT 1721 everything works fine the button that lights up the screen and the switch button doesn't work. in the UK Electrical Forum area at ElectriciansForums.net
Londra
Hello!I have a Megger MFT 1721 everything works fine the button that lights up the screen and the switch button doesn't work.
When you press it it sounds like it's going but it doesn't work
Is it something in the settings or malfunction?
[ElectriciansForums.net] I have a Megger MFT 1721 everything works fine the button that lights up the screen and the switch button doesn't work.
Looks brand-new, I'd take it back for a swap to see if it's the same. Or try the manual, I only have kewtech so can't comment on the operation.
Reply to I have a Megger MFT 1721 everything works fine the button that lights up the screen and the switch button doesn't work. in the UK Electrical Forum area at ElectriciansForums.net
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
