What is this? | on ElectriciansForums
Discuss What is this? in the UK Electrical Forum area at ElectriciansForums.net
Wiltshire
Hi all,
Does anyone know what this is? In the photo below it is the thing with the led light on, it's some kind of alarm and it's beeping. It's at floor level in a bedroom in a newish block of flats.
[ElectriciansForums.net] What is this?
The manual mentions:
Gases and vapours other than the target refrigerant gas, may cause semi-conductor sensors to react. Sensors exposed to silicon fumes may be permanently damaged. The accumulation of volatile organic compounds resulting from human occupation in a poorly ventilated room may cause inaccurate operation. Adequate room ventilation should be maintained at all times.
Not heard of this device before but it would be useful on a large system with many evaporators sharing a single large condenser unit.
Reply to What is this? in the UK Electrical Forum area at ElectriciansForums.net
Merry Xmas to all :D
    • Friendly
Thanks so much for sharing this with us! I’ll definitely take a look, it seems like there are a lot of useful and interesting products. The idea...
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
The core tech was never Google. The core technology was Nest, and it’s sound. They got bought up by Google looking for a way in to the home tech...
