Grommet strip alternative
littlespark
Staff member
Supporter
Patron
I’ve been having a brain fog moment.
I’m looking for edge protection for a straight cut in steel trunking.
“Grommet strip” in a search on CEF only brings up the small, flexible stuff for round holes.
The stuff I’m thinking of is straight, not flexible… usually black, but would prefer white if I could get it… Covers about 10mm or more on each side of the metal.
Spent all weekend trying to think of the right words to use on an online search that isn’t “grommet strip”
Recommendations and links please
I've at least a roll of it on the shelf (white) if you get stuck! I know it as glanding strip.
You got a photo, to see if it’s the stuff I’m thinking of. (With tape measure showing size)
The link shows the usual stuff from CEF…. But with an assortment of sizes. The sizes being the plate thickness.
I’m looking for the size of coverage on each side of the plate.
I guess what I’m really looking for is something that won’t fall off easily.
This is big stuff, more for pax boards than steel...
But also have smaller for use on trunking and cabinet holes....
The smaller size, roughly 3mm ID with about 2mm flange grips pretty well for most applications. I'll see if I can find a pic in use...
Thanks. That’s the small stuff I usually get from wholesalers for the back of boards etc. or the crenellated (?) type.
I’ve just seen this on eBay, which is more what I’m looking for.
Will have a good look tonight and buy it from there. Needing less than a metre really.
Ah! Gotcha.
Can't recall where but I daresay google would reveal, I bought a roll of grommet strip that has pressure activated glue inside. Wasn't cheap but omg. If regulars all I have I just cover it with some 1" duct tape which some might sniff at but V.
If you google this
"car panel edge rubber cover strip"
You will find a variety of sizes which might do the job.
Theye usually have a much wider coverage.
Mitre Bond is your friend with these.
Part Code: QGT3B
Stock Code: 2752-2406
we use this from cef if it's any help
This shows in stock at my local branch, even though they said at the counter they only had the little stuff. Have reserved it, as i need it quick now. Says 8mm cover... so should be enough.
littlespark,
sunray,
